  #21
Old 09-21-2018, 04:32 PM
JeffP JeffP is offline
Originally Posted by BradyWatson View Post
Now you're talkin'....I did 50,000 letters 1.5" tall for Federated Dept Stores (Macys etc), using commercial grade laminating adhesive, .090" styrene as a sacrificial layer and SintraTop PVC for the letters. When done, a little solvent wipe on the backside of the letters took off any adhesive still left on. I used vacuum to hold the whole git up down and a straight bit to leave chips IN the kerf to assist in side-to-side wiggle prevention because it was a very tight nest. I lost a few letter 'i' parts, but just would up running an extra 100 of them to make up for it. The glue ups were run through a laminator to make sure they were 'stuck real good' - so keep that in mind if you try it.
Hold down IS the entire job with this work...all else is gravy.
This is essentially how we cut small letters without a vacuum. If you add a layer of paint mask between the letter and adhesive there's no residue to clean up. Additionally if the material already has a paper mask- like acrylic- you can add the paint mask and dial in the DOC so it only goes through the paper- not necessary but can make extracting the letters a little easier. We're not cutting 50k at a time though.
Jeff Potts
Cobra 508 ATC
VCarve Pro
