Old 07-13-2013, 04:07 PM
Terry,
You do not have an FTC .... correct?
Do you have an auto on/off (via G-Code) for your router?
The way to test it is to start your CNC and computer using the normal start up process. once the CNC is Initialized do the following:
- Jog the router anywhere on the spoilboard
- Raise Z up 2" or more off the spoilboard (with or without a router bit installed)
- In Wincnc in the command box type M3 then press enter - if you have an auto on/off relay it will start the router
- Next in Wincnc type M5 them press enter - this will turn off the router.
Let me know what happens.
Old 07-13-2013, 04:23 PM
TErb2012 TErb2012 is offline
That is correct, I don not have an FTC.
I'm presuming the answer to the On/Off is yes for my spindle.
Did as you asked the command M3 turned the spindle on and M5 turned it off.
Standing by for further guidance/instructions.
Thank you
Terry Erb
CAMaster Stinger 1, Recoil, Spindle
Aspire 4.5
Old 07-13-2013, 04:57 PM
Terry,
Could you post the first 20 lines of your tap file
Old 07-13-2013, 05:09 PM
As requested:
G0Z0.8000
G0X0.0000Y0.0000
T1
SS9000
M3
G0X7.6095Y8.4445Z0.8000
G0Z0.2000
G1Z0.0000F30
G1X7.6233Y8.4297F100
G1X7.6768Y8.4898
G1X7.6414Y8.5690
G1X7.6095Y8.4445
G1X7.5540Y8.4306
G1X7.6244Y8.3547
G1X7.7359Y8.4806
G1X7.6275Y8.7302
G1X7.5540Y8.4306
G1X7.4983Y8.4166
G1X7.6255Y8.2790
G1X7.7930Y8.4690
Terry Erb
Aspire 4.5
Old 07-13-2013, 05:52 PM
Originally Posted by TErb2012 View Post
As requested:
G0Z0.8000
G0X0.0000Y0.0000
T1
SS9000
M3
G0Z0.2000
G1Z0.0000F30
G1X7.6768Y8.4898
G1X7.6414Y8.5690
G1X7.6095Y8.4445
G1X7.5540Y8.4306
G1X7.6244Y8.3547
G1X7.7359Y8.4806
G1X7.6275Y8.7302
G1X7.5540Y8.4306
G1X7.4983Y8.4166
G1X7.6255Y8.2790
G1X7.7930Y8.4690
Terry,
You don't have speed control on your router?
Here is your problem SS9000
Open your post processor CAMaster_Stinger_IN and delete the line in red below, save your post processor and then re-save your design files.
A quick option is to open your tap file and delete the line SS9000
begin HEADER
"[N] [91][TP_FILENAME][93]"
"[N] [91][TIME], [DATE][93]"
"[N] "
"[N] [91]MATERIAL size: [XLENGTH][34] x [YLENGTH][34] x [ZLENGTH][34][93]"
"[N] "
"[N] [91][TOOLNAME][93]"
"[N] "
"[N] G90 [91]ABSOLUTE MODE[93]"
"[N] "
"[N] M5 [91]SPINDLE OFF[93]"
"[N] G53 Z0 [91]LIFT Z TO TOP[93]"
"[N] "
"[N] [S] [91] SET SPINDLE SPEED RPM [93]"
"[N] M3 [91]SPINDLE ON[93]"
"[N] "
"[N] "
"[N] F[FC] XY [91]SET FEEDRATE FOR X AND Y[93]"
"[N] F[FP] Z [91]SET FEEDRATE FOR Z[93]"
"[N] "
You should be good to go after that
Old 07-13-2013, 06:10 PM
Mick,
Good evening, thanks for all the help. I thought I had speed control on my spindle (small control box on top of the control tower).?.? What specifically does that line control? I didn't modify the PP at all, I downloaded it straight from the forum.?.?
Apologize for all the questions/comments, guess I'm confused as to why it seems as if I'm the only one that has had this problem. Do I need to go in to the other two PP and delete that specific line? When I delete that line will it allow me to have speed control?
Terry Erb
Aspire 4.5
Old 07-13-2013, 07:33 PM
Terry,
I thought you had a router but I guess you have a spindle?
Could you update your signature block to show either spindle or router.
If Wincnc is still giving an error message let me know via the forum or call me a call 206-226-8344 I will be up till 11:00 PM Seattle time
Old 07-13-2013, 08:37 PM
Terry,
After looking better at the tap file you posted there is an SS in the line SS9000 which is causing the error ..... which of the 3 post processors did you use.
CAMaster_Arcs_inch
CAMaster_Recoil_X2A_IN
CAMaster_Stinger_IN
Old 07-13-2013, 09:09 PM
This is the PP I used CAMaster_Arcs_inch. I wanted to see if the if the CAMaster_Stinger_IN would give me the same error message which it did not. I appreciate your time.
Terry Erb
Aspire 4.5
Old 07-13-2013, 09:44 PM
Your welcome ...... Also there should be no tool callout (T1) unless it's an FTC or ATC machine.
Sorry for sending short messages I am really busy getting ready for my daughters wedding tomorrow, plus we have 12 guests staying at our house.
