Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Stinger Series CNC Routers > Stinger II
Old 02-07-2013, 10:44 PM
hefty hefty is offline
Default Footprint of 36 x 48 Stinger 2 w/o lathe?
The website lists 66 x 79 as the footprint for the 36 x 48 version. Could someone measure one of the new versions (with the motors on the outside) without the lathe. I understand that if ordered without the lathe, the gantry is centered over the table. We need to transport one in a van which has a 60.5" opening so we really need to know the widest dimension to pass thru the opening.
Thank's very much. John
Old 02-07-2013, 11:35 PM
MarkZ MarkZ is offline
Stinger Owner
The gantry is 69" wide. The base is 39x70. I had a 60.5" door at a room corner that I brought it in with the gantry on though it scraped the slightest bit. We may have angled it slightly to get it in.
Mark Z
____________________________
Stinger II 3x4 with recoil and Z+
Chapel Hill, NC
Old 02-10-2013, 06:37 PM
Default Height w/ counterbalance ?
Thank you Mark.
One more question: Does anyone have the dimension from the floor to the top of the cyclinder, or highest point, of the counterbalance for the 3.25 HP router upgrade? I assume it would be the same with either 36 x 48 or the 48 x 48 version of Stinger 2. How about clearance for air lines?
May have to remove shelving, hose reels, etc. and am trying to start prepping now.
Thanks, John
Old 02-10-2013, 07:07 PM
Originally Posted by hefty View Post
Thank you Mark.
Thanks, John
In my case with the spindle it is about 28.5 inches above the finished camaster table top. I have a custom set of legs on the table so floor to top wouldn't make sense for your measurements.
Old 05-02-2013, 03:23 PM
Speedy Speedy is offline
What is the table top elevation?
Larry
Old 05-02-2013, 08:16 PM
Larry
I had them build to a custom height so it is a little shorter than standard at about 34 inches. Shorter than my table saw.
