Old 06-23-2013, 03:09 PM
Default Where to place the post processor in Aspire or V-Carve Pro
Do not use the post processor the comes with Aspire or V-Carve Pro, CAMaster and Wincnc have written specific post processors for CAMaster machines.
Either download the post processor for your specific machine off the forum or contact one of the Knights, Moderators or CAMaster.
- Next start Aspire or V-Carve Pro.
- Click on 'file' in the upper left hand corner.
- In the drop-down menu, click on 'Open Application Data Folder'.
- Double click on the PostP folder.
- Create a new folder called un-used PP.
- MOVE all the files (not the folders) into your new folder.
- Now copy the post processor you saved into the original PostP folder (it should be the only file) there will be folders.
- Close all the folders.
- Restart Aspire or V-Carve Pro.
Old 06-23-2013, 03:10 PM
Continued
Check to see if the post processor is installed correctly
- Start Aspire or V-Carve Pro.
- Click on create new file.
- Enter width 5, Height 5, Thickness 1, Z0 wherever you want (these are just values not important)
- Click OK.
- Click on the toolpath tab icon.
- Click on the save toolpath icon.
See the section called post processor, if you click on the pull down menu you will only see one post processor unless you have a recoil in that case you will have two post processors.
I hope this helps ...... it is quicker to install the post processor than me making this message.
Old 06-23-2013, 06:52 PM
Hi Mick,
I noticed when I updated to Aspire 4.0 that Vectric has 6 CAMaster post processors included with their software now. I assumed that CAMaster provided them, of course I know what it is to assume.
Just to clarify should we or at least the new guys use these or continue to get them from CAMaster?
Nice write up by the way.
Mark
MC4848 (mini Cobra) 48 by 48
Aspire 8.0
Old 06-23-2013, 07:01 PM
Mark
Mark,
Good point I would use the post processor designed by CAMaster and Wincnc, I just viewed the post processor that Vectric provides with it's software and it's not the current version, there have been some changes made to the CAMaster version.
F[FC] XY"
F[FP] Z"
Feed rates for XYZ are not included in the Aspire post processor version
Old 06-25-2013, 08:31 PM
sscooter sscooter is offline
Mick
I have used the PP's from Aspire 3.5,4.0 and have no problems that I know of. If there are better ones here on the forum, were do we find them? I would need the ones for a Stinger1, Stinger1 FTC, and Stinger1 W/Recoil.
Thanks Again
Chuck Andries aka sscooter
Stinger 1 FTC with Recoil circa 2011
WinCNC Version 2.5.01
Aspire 9.014
and a couple of kegs of my Aspire Homebrew
sscooter@verizon.net
Old 06-25-2013, 10:27 PM
Originally Posted by sscooter View Post
Mick
Thanks Again
Here you go Chuck, these post processors are for an FTC machine, do you have the auto on/off relay? Keep you old post processor and add these.
Old 06-25-2013, 11:01 PM
Yes I have spindle on by G-code, I that's the main reason I ordered the FTC option. Now that I can use the FTC since fixing my INI file its pretty cool too!
Aspire 9.014
Old 07-06-2013, 12:02 AM
TErb2012 TErb2012 is offline
Can someone please send me the PP's please.
Terry Erb
CAMaster Stinger 1, Recoil, Spindle
Aspire 4.5
Old 07-06-2013, 07:38 AM
Terry, et al...
CAMaster posts are on the forum for Download in the Owners Only section: CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > CAMaster Owners Only > CAMaster Tech > CAMaster Post > Vectric Post
Old 07-13-2013, 02:44 PM
Default What now???
Good afternoon all, so I read this post thoroughly and twice for that fact. Much like "sscooter" I've used PP from 3.5 and 4 with no problem. However since then I followed the recommendations from many on this forum and updated my PP with the ones listed in the users Forum.
Following the directions carefully I placed the PP in the exact location identified in the previous post. I recently prepared a project to be machined and saved the toolpaths with the new PP and encountered the following error when I tried to run them on my Stinger 1. While in the WINCNC menu I can no longer use the view button without encountering the same error message depicted in the attached pic. I wanted to double check myself to see if I did something wrong and loaded one of my toolpaths with the older PP and everything worked fine.
I can easily load the PP that came with Aspire 4 however, if these are in fact the correct/most updated PP I should be using I'd prefer to use them. Any help will be greatly appreciated.
Here are the PP I downloaded for my Stinger 1 equipped with a Recoil.
CAMaster_Arcs_inch
CAMaster_Recoil_X2A_IN
CAMaster_Stinger_IN
Terry Erb
Aspire 4.5
