-   General Discussion (http://www.camheads.org/forumdisplay.php?f=48)
-   -   Issue with Vcarve process! Suggestions? (http://www.camheads.org/showthread.php?t=10805)
Cgriffith 10-29-2020 10:08 PM
I am going to try and be as thorough as possible here. We are having an issue specifically running a v-carve operation where the clearance tollpath is perfect, but when the v-bit tool path begins its plunge it does not stop at the scripted Z depth, keeps right on going into the spoil board.
Our set-up
Stinger III with X-3, primary spindle with two additional routers for those who might not be familiar.
VCarve-Pro
Post Processor: CAMaster X3 INCH
So, we just set the machine up last weekend, super excited. Neither my partner nor myself are strangers to layout and design, my partner is a machinist and well versed in code, machining, and mill work. I'm learning, honestly so far its fairly simple and straight forward.
We have successfully run profile and pocket cuts utilizing T1, the primary spindle. 1/4" endmill, dual flute, 15mm plywood. Perfect cuts, some tweaks to feed rate and what not, but other than that perfect runs.
We then started a Vcarve program. Used manual stops throughout. The EM in T1 cleared the bottom just fine. When T1 finished and T2, with the 90 degree 1/2" v-bit, fired up it moved to the correct X & Y and then ran down Z and kept going down. Hit abort and took a second to think.
Checked the sctipt. The T2 z should have started 0.800" above Z. First step brought the T2 Z to -0.12". Okay so that looked fine, thats where the run should have started.
Here is the code leading up to the ill fated plunge:
[VECTRIC CNC OUTPUT FOR CAMASTER X-3 ]
[MACHINES WITH WINCNC CONTROL ONLY]
[FILENAME: V-Carve for ref]
[09:01 PM, Thursday October 29 2020]
[MATERIAL size: 19.000" x 19.000" x 0.594"]
[Z Zero Position: Material Surface]
[TOOL LIST]
[2 = V-Bit (90.0 - 1/2")]
G90 [ABSOLUTE MODE]
M5 [SPINDLE OFF]
G53 Z0 [LIFT Z TO TOP]
T2 [ GET TOOL NUMBER 2 ]
[V-Bit (90.0 - 1/2")]
S16000 [ SET SPINDLE SPEED RPM ]
F70 XY [SET FEEDRATE FOR X AND Y]
F15 Z [SET FEEDRATE FOR Z]
G0 X-2.006874 Y-2.386122
G0 Z0.800
G1 X-2.006874 Y-2.386122 Z-0.120000
We went back and checked all aspects. Zeroed X and Y. Manually zeroed Z. Measured all tools. Touched off to material top.
We remade tool paths from scratch. Stepped through the entire program again and the v-bit again buried itself in the spoil board. Okay...
We took a different approach. Decided to see if it was just in the vcarve post, something getting confused somehow. We ran a profile cut with the v-bit in T2. Ran perfectly. Tried a small pocket toolpath with the v-bit, also ran perfect. Great.
So we decided to step through a vcarve set-up on T1 to see if the issue would replicate. Again all new toolpaths generated. Again, clearance endmill ran fine. We did a tool change to the vbit, touched top, start manually stepping through and the v-bit again went past the scripted Z.
Any thoughts, ideas, or help here would be greatly appreciated.
Thanks in advance!
Chad
sgodding 10-30-2020 08:30 AM
Can you post the actual VCarve file so we can see how the toolpaths are defined?
Flatlander825 02-13-2021 01:20 PM
There have been no follow up posts so I'm wondering if you figured out the problem? How are you setting zero for the T2 and T3? Are you touching off the surface or using the touchpad? All tools need to be zeroed. Don't ask me how I know....[book]. I'm still learning my X3 as well but these "hard" lessons tend to sink in better.
Steve Burke 02-13-2021 06:02 PM
Don't know if he found a solution, but I had the same problem to start. Then I figured out for my machine and my programming to just put the tool into the spindle, then set my Z to the top of the material. That's where I programmed it to and when I tried to use the touchpad with the machine for some reason it didn't work.
Cgriffith 02-13-2021 10:07 PM
Sorry for the delay there guys and/or gals. Yes we figured it out. It was actually in the coding in WinCNC. A quick call to tech support and a ten minute remote access fixed it.
I can't tell you how much troubleshooting we worked through trying to find the issue!
Cgriffith 02-13-2021 10:16 PM
Also as far as how we are running here is a break down.
Initialize
Measure T1
Measure T2
Measure T3
Double check Z
Touchtop and go
I always measure on initial start up. Probably not necessary but it takes like three whole minutes. Once everything is set we only touchtop if we switch part thicknesses and only remeasure if changing a tool, usually T3.
There is still something funky that happens if get tool is pressed on T3 after all measurements are finished. The native Z resets to bottom of the spoilboard. This why I run the Z down just to double check. In the grand scheme of things double checking Z height periodically has been a good habit.
And honestly touchtop has worked better for the majority of what we are running. It's not a milling machine but I prefer my cutting depth from too be more precise and have to deal with an onion skin or little spoilboard wear than countersunk holes or specific tool paths being too light or too heavy.
