Go Back   CAMheads CNC Router Forum By: CAMaster CNC > New CNC Setup. > General Discussion
Old 02-11-2019, 08:47 AM
Default spoilboard
ran the spoilboard wizard (great program - thank you Mick) on the mdf plenum, and it took several passes to get it all level of course.
once concern I have is that between the times I ran the program, set at default to remove 0.01", I would return the bit to Z0 and would have to lower the bit 0.05" to get the bit to the new level of the table. using the same XY position each time. this was repeatable the 6 times I ran the program. any thoughts or advice appreciated??
Panther PT-404 (aluminum)
6 position ATC w/5hpHSD, Aspire 9.5/WinCNC, Recoil, Laser, Hurricane
near bottom of the learning curve!!
Old 02-11-2019, 08:58 AM
John B John B is offline
Your Z 0 was set to the top of the spoilboard before you took off your first cut. It remains there until you tell it otherwise, even though the top of the board is lower than the machine thinks it is by the depth of the cut.
If you're changing the depth of the cut on subsequent passes in order to have the bit "meet" the top of the spoilboard, you're going about it wrong because you're "cutting air" before you get there. Re-zero the top of the spoilboard each time you take any off.
This is one of those times you want to set Z0 at the top of the board because the objective is to "shave" a little at a time until you get it true (rather than dialing in what you want your ultimate material thickness to be) and there's "no math involved" this way.
Old 02-11-2019, 10:27 AM
Like John said...normal behavior. The utility expects you to reset Z0 before each time you run the program because that's its reference point for where to start taking off material.
And yea...great utility. Once you save the toolpath, you can use it "forever" for your machine unless you want/need to change the amount it's shaving off.
Old 02-11-2019, 11:51 AM
thank you John and Jim!
I may not have expressed myself well ( and typically don't you can ask my wife!!). I understand that a new Z0 would result after each subsequent material removal. the part I am concerned with is, the program said it would remove 0.01" (this would be in the Z axis as I understand it), but after the cut, I have to lower the spindle 0.05" from the latest new Z0 to reach the new table height. when I really only expected to have to lower it 0.01".
Old 02-11-2019, 12:01 PM
SteveNelson46 SteveNelson46 is offline
This might seem like a dumb question but, are you resetting the z-zero at the exact same location each time?
Steve
Camaster Stinger 1 with Recoil
1hp Spindle
Wireless Pendant
Aspire 9.5
Old 02-11-2019, 12:17 PM
Ed Hazel Ed Hazel is offline
How are you determining the new Z0? touchpad or manually with the paper technique?
Ed Hazel
Stinger II 44
508 Cobra ATC
Old 02-11-2019, 01:32 PM
manually (paper technique). yes, I reset Z0 for each pass of the program, in the same location. thanks again for your help!
Old 02-11-2019, 02:24 PM
hi Jim, not sure if I am understanding your process, but I believe that after you have lowered the bit to the table top, the program sets Z0 (early) before the machine moves the head/gantry. thanks for your input!
Old 02-11-2019, 03:43 PM
Yes, that's true...the utility does the deed for setting Z.
Old 02-11-2019, 06:20 PM
Am I wrong in thinking the Safe Height for the Z is .04 (above the last Z0) and the spindle is returning to that height after completion of the cutting program?
That would account for having to move .05
