Old 08-12-2019, 09:20 PM
JonnyU JonnyU is offline
Default Ftc
So I got my spoiler board done then ran into another problem. Pressed measure tool one and z dropped down till it broke the tip. Donít know what happened as it worked the last 20 times I used it. Any ideas how to fix this ?
https://youtu.be/4eEm2ZdgoQw
Old 08-12-2019, 10:38 PM
check to make sure it didn't come unplugged at one end or the other
Tom Klass
Klassic Custom Woodworking
Stinger. 1 with recoil lathe
1.7 kw spindle
Old 08-12-2019, 10:49 PM
Charlie_L Charlie_L is online now
Jonny,
As you push on the switch like in your video, does "view Inputs" light up an input for the switch? Use the menu View and Inputs to watch what is happening as you push.
Old 08-13-2019, 01:09 PM
Okay emailed Camaster last night waiting on response. I disconnected the two DB-37 and cleaned them with compressed air. Still not working. I looked at the inputs and I donít see any changes on the inputs. I also disconnected switch and ring it out and it works perfectly with a multiple meter. Also just noticed the touch top not working. So thinking itís control board issue.
Old 08-13-2019, 01:51 PM
John B John B is offline
check continuity on the touch off device.
Old 08-13-2019, 02:02 PM
Do you mean touch top device ? How do you do that ? Sorry very new to this .
Old 08-13-2019, 03:01 PM
You can hit the touch top button and just pick up the sensor and touch it to the bit before it gets anywhere close to the top. Hit Esc to stop the Z if it doesn't stop with the sensor.
Also I have seen some people post on here that leaving the touch top sensor sitting on the metal case will make it act odd. Set it on a board or something non conductive or unplug it when not actually being used to set to tool offset.
Just check everything over in general for loos connections or something that catches your eye.
Talk with tech support before you really tear into anything. Hopefully it's a simple thing.
Old 08-13-2019, 04:32 PM
If you have had your FTC already enabled by the Camaster tech (they do not come from the factory with it enabled), there will be only rare moments when you will use the metal touch puck for anything. That's the whole purpose of the FTC. The calibration process where you touch the table/spoil board top after surfacing it so the machine understands the Z zero is a one time process and is only done when the level of the spoil board changes. If you have followed the instructions for the FTC operation exactly and your machine is still burying the bit, "something is amiss".
So...did you call in to Camaster and have them enable the FTC? if not...that needs to be done for it to work properly.
Old 08-14-2019, 12:02 AM
Okay got it fixed. Bad input on circuit board. Moved it to another location and it fixed the problem. Support at Camaster walked me through it.
Do they send starter bit set with new machines?
Old 08-14-2019, 08:23 AM
When I bought my machine you had to buy the starter bit set. If you didn't just buy some online.
If you're not sure what you need, talk with Joey about the work you'll be doing on your new camaster and he can get you bits that make sense for your applications. Let him know what machine you have so he knows what it can handle. @ https://www.usroutertools.com/Default.asp
