Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > CAMASTER TRAINING AND MEETINGS
Old 11-30-2019, 07:55 PM
Deancreates Deancreates is offline
Default Post Processor Error VCarve Pro V10
I just tried to use the new multiple clearance tool option on VCarve Pro V10. I kept getting a "syntax" and "file not found" error when I tried to load in into WinCNC on my Stinger 3. I ran the clearance tool function on V9.5 and it ran just fine. The engrave function also didn't work for single tool engraving on V10 either. Any suggestions?
Old 11-30-2019, 10:47 PM
ADMINISTRATOR
Are you on the latest .07 release? It just came out a few days ago and fixes a bunch of issues that caused them to pull back .016.
Old 12-01-2019, 09:22 AM
CNC Consultants and Trainers
1) What was the name of the file?
2) What post processor did you select?
Servo Control Upgrades
Old 12-01-2019, 12:29 PM
The post processor is CAMaster ToolchangeINCH (*.tap)
The file name is coditotem9.5.tap
It appears the Syntax Error or File Not Found message pops up on the tool change function. I tested the file with no tool change (no clearance) and it runs fine. (SingleToolINC (*.tap))
Old 12-01-2019, 12:37 PM
I'm not sure what this means
Old 12-01-2019, 01:10 PM
Michael Mezalick's Avatar
CAMaster Owner, (MOD, KOTR)
What does it say at the top left of the software.
It will tell you what version you're using.
If you have something different click on the "help" tab and select the "Check fo updates" option
Michael
Michael Mezalick
Cobra, WINCNC
3-D Modeling
https://carveddetails.com
mm@mezalick.com
Old 12-01-2019, 01:27 PM
It means that your machine is setup for single tool operation. No ATC or FTC (or FTC enabled)
Use the Single tool postP
Remove the punctuation from your file name.(extra period) dash and underscore are supported, no others
Old 12-01-2019, 05:51 PM
I had FTC enabled on my machine a few months ago and it ran once yesterday but now it doesn't run with any FTC operations, even when I correct the file name as you instructed. It appears I'll need to contact support to set it up again?
Old 12-01-2019, 06:47 PM
That is a question for tech support
Old 12-02-2019, 10:55 AM
DVE2000 DVE2000 is offline
What's the tool number? I can't remember what the error message is if a tool is greater than ten. I have this tool renumber gadget I wrote that fixes this. Gary LOVES it.
Gary
Fusion 360
