Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > CAMheads Show Room
Old 03-15-2017, 03:55 PM
Default Corian epoxy inlay sign
So, I'm am in love with Corian. I went back to using West System epoxy, had issues with the other ones changing the color when adding the hardener. With colors I really need to be true I use the "207 special clear" hardener from West.
Bob
File Type: jpg 5603212F-8AE9-4DEC-99B0-9F95A8C810CA.jpg (94.5 KB, 235 views)
Bob Walters
Lebanon, Ohio
2016 Stinger II SR-44
3.0 kW Spindle
Vectric VCarve Pro 9.xx
www.cool-signs.com
Old 03-15-2017, 07:38 PM
gachua gachua is offline
Really nice !!
What pigment did you use for red? I need a better red option. The one I have is more of a dark burgundy.
Glenn Chua
gachua@gmail.com
Morrisville, NC
CAMaster Stinger III
Old 03-15-2017, 08:37 PM
Originally Posted by gachua View Post
Really nice !!
I used Mixol, it went way to burgundy on me because I actually used the other epoxy with the hardener that messed with the tone. If I had used the West Epoxy it would have been a brilliant red. The blue is West Epoxy. The Mixol stuff is great, I put in 2-3 drops per pump of the west to make it more opaque otherwise it's a bit too translucent.
Bob Walters
Lebanon, Ohio
3.0 kW Spindle
www.cool-signs.com
Old 12-20-2018, 11:52 AM
DVE2000 DVE2000 is offline
Has anybody used System 3 epoxy resin to inlay into Corian? I'm about to buy some colors to do that with, and it's expensive stuff...
Gary
Fusion 360
Old 12-20-2018, 12:48 PM
I use fiberglass, these are 8 years old
Old 12-20-2018, 01:24 PM
Thanks for the info, Jim. Do have a particular brand of resin? Do you buy it colored or mix some sort of dye or powder in it?
Gary
Fusion 360
Old 12-20-2018, 01:37 PM
tenax , touchstone, Granite supply companies like Gran Quartz sell it $$$$ or Amazon (much less)
Some colors use a few drops (Darker), some like yellow and white need more
The fiberglass comes from lowes, autozone etc, if you want a White White you have to add more colorant
https://www.amazon.com/Tenax-Piece-U...poxy+color+kit
Old 12-20-2018, 02:00 PM
Thanks again, Jim. I ordered that kit, as well as a gallon of Bondo fiberglass resin. That should last me awhile. The Amazon price for the resin was equitable to local suppliers.
Gary
Fusion 360
Old 12-20-2018, 02:49 PM
Works well for me
Old 12-20-2018, 02:51 PM
Remember those who read this, there is a difference in Flowing and Knife grade epoxy, you do not want knife grade.
Unless you want Knife grade !
