Go Back   CAMheads CNC Router Forum By: CAMaster CNC > New CNC Setup. > General Discussion
Old 11-30-2018, 03:47 PM
Default Mdf to phenolic
I couldn't find very much info on adhering a MDF spoilboard to a phenolic plenum, not just screwing it down. Has anyone done this or does most everyone just drill and tap the phenolic and bolt the MDF to it?
I'm trying to avoid having to turn the vac pump on everytime I cut sometime to pull the spoilboard down to the plenum.
Any advice would be great on what your solution was.
Wes
Steel 5X10 Panther
VcarvePro 9.5
Old 11-30-2018, 08:26 PM
Hallex Hallex is offline
Camaster owner
I silicone the edges of mine
Camhead FAN
Old 11-30-2018, 08:43 PM
3M double sided tape. Tape it turn on vac for a few minutes and then surface.
*this is all after you surface one side and flip over.
www.usroutertools.com
Old 12-01-2018, 06:36 AM
I had one machine with a Phenolic and have a phenolic that was never Installed on the Cobra,
I was unsuccessful in adhereing the SB to the phenolic, We do use the Glue down on the Cobra with the MDF Plenum, With the Phenolic I screwed it down with Nylon Hex head bolts.
https://www.mcmaster.com/nylon-bolts
Old 12-01-2018, 07:47 AM
srhardwoods srhardwoods is offline
I have MDF on my phenolic plenum. Best way is to make a file that drills and countersinks holes through the MDF into the phenolic plenum. Then pull the MDF off, tap the holes in the phenolic, silicone all around the perimeter, then install the MDF, use nylon screws to adhere the MDF. paint the edges. I did that 2.5 years ago, still using the same piece of MDF. I use a 1/4" MDF as my sacrificial board. I get about 30 sheets of material out of the 1/4" MDF. I have never had to replace the 3/4" MDF.
I'll take some pics when I get in the shop
Chris Vickers
Somerton Ridge hardwoods
www.srhardwoods.com
Cobra 510
10HP ATC
Vacuum Table
Old 12-01-2018, 12:47 PM
Here are the photo's
Chris Vickers
www.srhardwoods.com
Cobra 510
10HP ATC
Vacuum Table
Old 12-01-2018, 02:45 PM
DVE2000 DVE2000 is offline
I just said in another thread that Luke suggested Shurtape indoor/outdoor carpet tape to me. It works really well. https://www.lowes.com/search?searchT...pe+carpet+tape
Gary
Fusion 360
Old 12-01-2018, 02:52 PM
dwolbeck dwolbeck is offline
Gary,
Do you just tape the perimeter of each zone. Or a few spots in the middle too?
Dennis Wolbeck
SR-44
3.25 HP router
T-slot table
Vcarve software
Old 12-01-2018, 03:08 PM
Originally Posted by dwolbeck View Post
Gary,
Luke had said that the perimeter is enough, but I had to trim the thickness of the tape and had these long pieces left over, so I added a little square piece of tape to every second square piece of phenolic. Iíve seen MDF move before, so I think this was a good thing to do. Iím not always cutting with the vacuum turned on.
Gary
Fusion 360
Old 12-01-2018, 04:44 PM
Yep. That would be my thinking as well.
Dennis Wolbeck
SR-44
3.25 HP router
T-slot table
Vcarve software
