Old 10-06-2020, 05:25 PM
Carpenter Carpenter is offline
Default spindle does not spin
Hello everyone :
I can not turn my Stinger 1 spindle (not router) to spin. I thought it should be like a drill press to work once power on. Could you help me with some resolve?
Carpenter
Old 10-06-2020, 05:38 PM
The button on WinCNC Stinger screen should turn the spindle on/off. Does the button change from red to green?
Also, typing "m3" or m5 on the command line in WinCNC should turn it on and off.
WinCNC 2.5.03, Aspire, PhotoVCarve, Windows 7 Pro SP1
Old 10-06-2020, 05:54 PM
Hello Charlie:
Yes, I have hit the spindle on and off numerous times, no reaction, but a slight "click" from tool box.
Old 10-06-2020, 07:28 PM
What color light on the buttons? I assume green.
Check the VFD display. What does it tell you? Is speed set at zero, then it wonít turn.
Iím guessing you have a new machine. Maybe time to contact the factory?
Old 10-06-2020, 08:53 PM
Hello Charlie:
the button does change green, I pull off the white date cable, reconnect it, the spindle turn now, so the cable is not high quality one. By the way, What is VFD display? Thank you.
Carpenter
Old 10-06-2020, 08:59 PM
Logan Y Logan Y is offline
Cables come loose, especially in transit. If the connection is even marginally loose it can cause issues. It doesn't have anything to do with the quality of the cable.
4'x8' Stinger IV w/ 4.2 hp spindle and 4 tool ATC
Mister system
Phenolic Vac table
Hurricane Vac
Vcarve Pro 10
Catholic school IT director, wannabe woodworker, Krav Maga instructor, and CNC enthusiast
Old 10-06-2020, 10:50 PM
If you get an odd problem check that multipin cable 1st. Every once in a while I have to take mine loose and blow it out and reconnect.
VFD display is the screen on the spindles drive, you shouldn't have to mess with that. It's the biggest thing in the control panel I believe.
Old 05-04-2021, 01:29 PM
Racegrafix Racegrafix is offline
Mine wont work either, I will check wiring and see whats going on.
Old 05-04-2021, 01:36 PM
Everything looks tight on mine. The two router power cables (X3 model) was extremely poorly run and would 100% fail if not fixed, but thats easy enough to correct. At this point, camaster should drive here and get this thing working, getting sick of wasting my time figuring out stuff that should have been done.
Update - Post processor for X3 does not activate spindle, so the single tool PP must be used, or edit the code.
Old 05-04-2021, 02:13 PM
Race you need to call CAMaster and setup your orientation if you haven't already. A lot of the issues you are reporting so far would be covered and resolved with the free orientation session with tech support. We're here and happy to help but it would make your life easier if you went through the orientation with them.
Mister system
Phenolic Vac table
Hurricane Vac
Vcarve Pro 10
