  #21
Old 01-02-2019, 07:49 PM
Originally Posted by rcrawford View Post
I'd post some pictures, but I can't seem to get pictures to work on this forum anymore. . .
If you happen to be using an iPhone, and have the latest IOS version, by default it doesn't save JPEGs anymore. It uses a more efficient and less lossy compression called HEIF, which this forum can't handle. You can go to camera options and choose "Most Compatible" instead of "High Efficiency" to save photos as jpegs again.
  #22
Old 01-02-2019, 08:16 PM
Russell, that's quite the adaptation you describe with using the traditional lathe in place of the recoil. Very kewel!
  #23
Old 01-02-2019, 08:59 PM
Very create Russell. Thanks for sharing the details.
Mike Davison www.DavisonWoodworks.com
Stinger II with Recoil, GCNC Sidewinder Lathe, Aspire, Sketchup
  #24
Old 01-02-2019, 09:33 PM
I recently removed the recoil from my Cobra and set my variable speed lathe up in its place (fastened it to the concrete to hold it in position).
#1: If there are no pictures, it didn't happen!!
#2: If there is no video, it doesn't work!!
  #25
Old 01-03-2019, 07:36 AM
neal_meyers_jr neal_meyers_jr is offline
CAMaster Cobra Owner
Send a message via Skype™ to neal_meyers_jr
Cool
Very nice work. Now that my Barn is up and running I am looking forward to getting back into the rotary work too.
Owner with Recoil
Neal Meyers Jr
Guyton Ga
Aspire 4.0, WinCNC, Rhino, Mastercam, Autocad, Catia.
  #26
Old 01-03-2019, 07:44 AM
Cool
Gary you forgot " If it is on tv or the internet it IS true."
Also if your CNC did not come with the indexing option it may not have the over travel to reach a stand alone lathe.
I like the idea Russel and had thought about doing the same thing with a VS pen lathe as an experiment. Gary's inspiration. I was going to attach it to the recoil rails and test it.
Owner with Recoil
Neal Meyers Jr
Guyton Ga
  #27
Old 01-03-2019, 09:03 AM
SteveNelson46 SteveNelson46 is offline
Yes, I dragged the lathe over to the position that the recoil was (After removing the recoil completely) and then set it up thin shims to be exactly parallel to the Y axis (and consistent Z from headstock to tailstock), then fastened it to the concrete so it wouldn't shake out of position. Then I just use the spindle as a lathe tool.
I can round a 30" x 2" square block in about 3 minutes, to a perfect 2" round. I did this so I could make some turned legs for a Hans Wegner chair I reproduced, and it worked wonderfully. I use a 1/2" end mill to round the blank in a single pass, then a 1/2" ballnose to cut the profile in a single pass. I turn the lathe at 175rpm in reverse and move the gantry up the Y axis at 10ipm with the spindle at 18000rpm. Then I lock the indexer and cut in my mortises. This set-up has worked WAY more efficiently than the recoil ever did, and I can turn the lathe up to 1200rpm to make sanding easier.
Just for fun, I cut a bunch of french rolling pins for family for christmas. Single pass (no rounding pass first), 90 seconds each plus time for sanding on the lathe. Having the morse taper is much handier than the recoil threaded rod as well. . .
Russ,
This sounds like a great idea for just spindle work. Unless the Cobra actually controls the rotation of the lathe you may have some difficulty with 3D carving or spirals.
Steve
Camaster Stinger 1 with Recoil (2019)
1hp Spindle
Laser crosshair
Wireless Pendant
Aspire 10
