Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Software > Cabinet Parts Pro
Old 10-09-2014, 08:01 PM
dubrias
Guest
Posts: n/a
Question Run time error 76
THIS IS MY FIRST TIME TRYING IT (FREE VERSION)
This is my problem: I write down the dimensions IT APPEARS RUN TIME ERROR 76 (PATH NOT FOUND) AND CLOSE THE PROGRAM, ANY HELP?
Old 10-09-2014, 08:07 PM
ChrisAlb ChrisAlb is offline
Stinger Owner
You will probably need to provide a bit more info in order to get some help.
What application are using, what function are you trying to perform when you get the error, etc. You might also want to attach a picture to your post showing the error message as well.
Chris Albright
Stinger SR23, Porter Cable 2.25 hp
Vacuum Table
Z-Plate / Laser
Aspire 8.5
Old 10-09-2014, 08:17 PM
dubrias
Guest
Posts: n/a
Default Cabinet parts pro
Its cabinet parts pro the trial version i just cannot start as soon i type a dimension it appears and close the program
Old 10-09-2014, 08:40 PM
Ryan Patterson Ryan Patterson is offline
cabinetpartspro.com
Sounds like something with the settings is missed up. You can restore the default settings by going to help then about. When the about window opens click the reset button. I hope this helps.
Old 10-09-2014, 08:51 PM
dubrias
Guest
Posts: n/a
Unhappy Reply
In the free version the reset button does not appear... It appears but you cannot click it...
Old 10-09-2014, 09:00 PM
Excellent software, we ran 120 sheets with it since Monday, My crew have finally caught on !!
Old 10-09-2014, 10:17 PM
cabinetpartspro.com
What language do you have Windows Set to?
Old 10-09-2014, 10:33 PM
dubrias
Guest
Posts: n/a
Default Windows in spanish
Spanish is in spanish i am from mexico
Old 10-13-2014, 07:11 PM
dubrias
Guest
Posts: n/a
Default Is there something i could do
I dont know is there something i could doto fix the language problem and run the program am really interested...
Old 08-19-2015, 05:55 PM
Charliefan Charliefan is offline
Hello everyone,
I am Carlos, Costa Rica.
I have an office furniture manufacturer company and use two CNC routers. I intend to buy another machine but I find intutivo nesting software.
I'm trying to test the free version and the same happens to Dubrias occurs.
I tried it with three computers, windos xp, 7 and 8.1. (spanish versions)
Same problem (Run Time Error 76)
Honestly I care very much the software because I believe we can quickly prepare files for nesting G-code without having to go through the process of CAD drawing, but I try before I buy the license.
Any suggestions?
